dependence of orifice length on pressure drop
Haqy
i am searching the dependence of orifice discharge coefficient on orifice length (what is the change of dicharge coefficient on different orifice lengths)
for example : at given flow, orifice diameter and pressure drop change orifice length. what is the flow change?
is there some equation?
thank you
thank you
RE: dependence of orifice length on pressure drop
The reference is : William B. Hooper, Calculate Head Loss Caused by Change in Pipe Size, Chemical Engineering, Nov 7, 1988, pgs 89-92.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
Good luck,
Latexman
