involute curve
involute curve
involute curve
hey i need to calculate an involute curve for a rocker acting on a valve stem, does anyone know how or know of any literature ?
cheers
RE: involute curve
i assume rocker pad design of the involute curve is the same as it is for gears but just want to be sure
RE: involute curve
Think of it as a rack-and-pinion with one tooth.
RE: involute curve
I question what an Involute has to do with this application. Wouldn't a standard Cam curve with a controlled motion be better or is the stroke so minimal that it doesn't matter?
