What is thin-wall?
3
What is thin-wall?
What is thin-wall?
How do I find out what it is thin-wall, according to item 11 of ASTM A-106?
Please friends, if possible with some examples.
Thank you all
RE: What is thin-wall?
No clue what you are asking regarding thin wall. Item 11 is what? There is Section 11 in ASTM A 106, which deals with Bending Requirements. Please re-state your question.
Thank you and sorry for the confusion. You are correct.
I do not quite understand what is thin-wall section 16, item 16.2 of ASTM A-106, or 11.2 of ASTM A-530.
Thank you all
Section 11.2 of A-530 deals with ordered lengths of forged and bored. cast and CastCold-wrought pipe. Per 10.2 "Thin wall pipes pipes are defined as having a wall thickness of 3% or less of the outside diameter."
Thin wall... I use it to name pipe Below sch 10 pipe size and not qualified as tube
Thank you my friends!
