material selection in sulfuric acid
i need to select material for pump shaft in sulfuric acid at 98% concentration and 120 C. i would like to know any one has experience on chrome plating coating on this application or maybe kindly suggest another solution.
RE: material selection in sulfuric acid
http://www.peerlesspump.com/fire_pumps_appnews07.a...
Second, review information on suitable materials and the effects of velocity. Ni-base alloy would be required given flow induced effects on material performance and 120 deg C.
Third, chrome plating would not be recommended for this application.
It is the best Sulfuric guide that there is.
Plymouth Tube
