Modelling equation
Modelling equation
I have a system as attached in the picture. Its a cooking vessel filled with water, resting on a heating plate. The vessel has the
form of a half sphere, with the exception of the area in contact with the heating plate, which is plane.
I derived an equation for the temperature of the vessel which I have also written in the picture under the system. In the equation T is the temperature of the vessel itself, and Tw is the temperature of the water.
In the model a term containing the first derivative of the temperature appears, even though there is only heat conduction (commonly represented by the second derivative of the temperature). I want to know what does the first derivative represent here? (i.e. what is the physical meaning of the first derivative?)
Any help would be appreciated.
RE: Modelling equation
Good luck,
Latexman
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
