GE Fanuc programming software
In the past few years a client of ours has purchased several packaged skids with the GE Fanuc 90-30 series plcs running the controls. They are wanting us to provide primarily program save/storage and reload corrupted program functions. Also may have a need on rare occasions to modify a program, or add rungs to utilize spare I/O.
I was wondering what might be some good software for the 90-30 either GE or aftermarket etc.
RE: GE Fanuc programming software
There is at least one commercial multiple vendor source management system, though I cannot remember what its called at the moment. If I remember it I'll post it up here. (I've done a half dozen searches already, its not coming up).
We'd only looked at the commercial option briefly, then went to SVN as its open source and we had a lot less issues justifying purchase cost on this basis. Any diffing or compare functions are still done via the native PLC software, as SVN diff doesn't support our binaries.
Someone elsewhere mentioned that GIT has an advantage in that every repository is a full local copy, whereas for updates SVN needs a remote server. We (attempt) to manage this by trying to ensure that releases are done before people head to site, but it doesn't always happen.
I don't have any experience with GE explicitly though, all our gear is either Omron or AB.
Never used it, no idea what its like, but it appears to support much more in the way of binary files than the open source systems do. At least worth a look, there aren't many out there.
You can find a them from here: http://support.ge-ip.com/support/index?page=spage&...
http://www.ge-ip.com/products/proficy-change-manag...
