Gear Position.
Gear Position.
Halo, anybody knows any way to determine a gear position? i.e the gear of a motorbike is undetermine since is only an up and down, is there any ways to determine the position except by counting the number of times that gear have been tap.
RE: Gear Position.
Cheers
Greg Locock
RE: Gear Position.
thnx
RE: Gear Position.
There will be no force in the linkage after the gear is engaged, and the force during the change will not just (in fact not much at all) depend on the two gears that you are switching between.
Cheers
Greg Locock
RE: Gear Position.
RE: Gear Position.
www.datatool.co.uk/digi.html
www.translogicsystems.co.uk
Cheers, Bob
"Faster than a Speeding Pullet"
www.rortydesign.com
RE: Gear Position.
If you are at low RPM and/or want more response, change down one, and vice versa.
Different story in a car with "H" pattern gates.
pat
RE: Gear Position.
In a bike engined car, the gear selection is sequential, as on the bike, so there isn't the H pattern to judge which gear you're in, which can be very frustrating. I know, I race one.
