shear wall unsafe in shear
Hi guys,
when u build a 3D model and after running the model, u notice that one of the many shear walls is unsafe versus shear (the other walls are safe), what i generally do is the following and would like to share my thoughts with you :
1- assign modifiers for f12 (0.7) so the wall could give some of the carried shear to the adjacent walls which the modifiers are unchanged.
2- Model the wall as a column so it wont get the transfered shear and will be distributed to the adjacent elements.
your thoughts are appreciated.
thank u
thank u
RE: shear wall unsafe in shear
You have a few options:
1) If you change it to a column, you have to also change your construction details to ensure load can't transfer into it. How you do this depends on construction type (using sliding connections, etc.).
2) Strengthen the wall, by adding reinforcing/section/etc. until it can handle the loads.
3) Shrink the wall/enlarge the other wall so the shear distribution is more to your liking.
It's hard to know which (if any) of these is necessary without knowing more about your modeling program, construction type, etc.
Brian C Potter, PE
http://simplesupports.wordpress.com
