Bunker Fuel 100' storage tank design help
Dear community,
Does anyone have an advice for designing a Bunker Fuel (IFO 180) Storage Tank with 100' DIA?
Thanks in advance,
Faustini
Thanks in advance,
Faustini
RE: Bunker Fuel 100' storage tank design help
The general advice is to determine the required capacity of your tank with the maximum height and diameter and submit an inquiry to an experienced tank fabrication firm. There are several (in the USA) that deal in tanks this size. These firms can do a complete design and minimize the chance for errors resulting in injuries or product loss.
Thank you for the quick response. Your recommendation is noted.
You must consider:
- In-tank steam heaters
- Steam heated discharge nozzles
- Condensate collecting systems
- Venting of light hydrocarbons
- Insulation selection/supporting
- Corrosion allowance on tank wall
- Under tank bottom insulation
- Problems with tank internal circulation
This massive tank size seems to make little sense....Why are you storing such a large volume ?
Do you have many, many boilers to fuel for weeks at a time ?
Somehow, was there an MBA involved in the tank sizing decision ?
Will the pumps used to fill this tank be able to meet the high Head/SG requirements ?
You must be designing this tank for storage of bunker fuel at a refinery, not at a user installation.
A full tank of this size represents a fairly large amount of money. Hence, I was a bit curious about the size
Be sure to include a water-draw-off nozzle, or a sump with nozzle to remove settled water.
I'm considering the draw-off sump. Thank you.
MJCronin
I suppose you're talking about a circulation vent? What about an IFR along with a cone structure supported roof?
The tank will storage 62,900 barrels (10.000 m³) and will supply ships that enters the Amazon River.
About your last two questions, I'm sorry but, what is an MBA? Our main shareholder said to me to design 5 tanks, I suggested him that is more economical to design only one. And about the pumps, could you explain clearly? We have a plain area near the river.
Thanks in advance,
Faustini
Not an easy task for a single tank of this size. This is the single biggest advantage to multiple smaller tanks.....
What I meant to say about the pumps was:
"Will the pumps used to fill this tank be able to meet the high Head/SG requirements at the range of viscosities expected for your installation ?"
You may require large PD pumps instead of centrifugal pumps because of your combination of head and viscosity
With regard to tank venting, it is not unusual for the headspace of a bunker fuel tank to develop a high/toxic concentration of H2S......
http://www.countrymark.com/countrymark/Portals/0/N...
You must consider the use of commercially available additives to defeat the biodegradation and sludge formation in the water layer at the tank bottom.
http://www.guardiancsc.com/pdf/fuel_oil_treatment....
I believe that you should consider multiple Bunker Fuel tanks (at least two) to allow for storage and delivery during the inevitable repairs, cleaning and inspections necessary for this type of tank.......
Anyone else have thoughts on this ??????????
Your massive tank will require continuous and complete circulation of Bunker fuel
It means if I split the tank, agitators are not needed (?)
We just recently had had a customer call up and request a cost for a field erected Froth Tank. I designed the tank at 36.5 meters in diameter and 30.4 meters tall with a internal cone. The cone itself was 24.3 meter long (tall).
Shipping weight for this monster was at about 3 million lbs.
7 million dollars is just a drop in the bucket for the big boy oil company's.
Cheers,
LGW
Which arrangement is best choice for the tank heating system?
Arrangement 1:
Heat exchanger (TEMA type BEU) inside the tank,
Water boiler (water from the nearby river) using the same bunker fuel as combustible;
Arrangement 2:
Pipe insert heaters
Mechanical mixer for temperature uniformity purposes
