Parameterisizing Splines
Is there any way to parametrize points on a splines using expressions?
RE: Parameterisizing Splines
Otherwise you could have an expression used for the plane distance from the x-y plane and within each sketch the dimensions for each direction would reference the relevant expression.
I don't think you can set point coordinates as an expression, at least not with UG 7.5
Or you can go directly to the Studio Spline thru Points function and when you're asked to 'Specify point location...' select the last icon in the Snap Point section of the Selection Bar labeled 'Point Dialog' and when the dialog comes up change the 'Type' to '= By Expression' where you will now be able to directly create 'Point Expressions' for each one of the Spline Points, resulting in a fully 'parametric' Spline.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
