Help with Journal to edit object display on solid bodies
Trying to create a journal to edit object display (chabge colour to a preset value) of any pre-selected solid bodies.
I have tried the below, but I still have to select "solid body" from the selection filters for it to work.
Any help greatly appreciated.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: Edit->Object Display...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start")
theSession.SetUndoMarkName(markId1, "Class Selection Dialog")
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Class Selection")
theSession.DeleteUndoMark(markId2, Nothing)
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Class Selection")
theSession.DeleteUndoMark(markId3, Nothing)
theSession.SetUndoMarkName(markId1, "Class Selection")
theSession.DeleteUndoMark(markId1, Nothing)
' Dialog Begin Edit Object Display
' Dialog Begin Color
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Object Display")
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = False
displayModification1.ApplyToOwningParts = False
displayModification1.NewColor = 186
displayModification1.NewWidth = DisplayableObject.ObjectWidth.One
Dim objects1(0) As DisplayableObject
'Dim body1 As Body = CType(workPart.Bodies.FindObject("BLOCK(1)"), Body)
Dim body as DisplayableObject
Dim Resp as integer
Resp=SelectAnObject ("identify body",body)
objects1(0) = body
displayModification1.Apply(objects1)
displayModification1.Dispose()
' Menu: Tools->Journal->Stop Recording
End Sub
Function SelectAnObject(prompt As String, _
ByRef selObj As DisplayableObject) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim cursor As Point3d
Dim typeArray() As Selection.SelectionType = _
{ Selection.SelectionType.All, _
Selection.SelectionType.Faces, _
Selection.SelectionType.Edges, _
Selection.SelectionType.Features}
Dim resp As Selection.Response = theUI.SelectionManager.SelectObject( _
prompt, "Selection", _
Selection.SelectionScope.AnyInAssembly, _
False, typeArray, selobj, cursor)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
End Module
RE: Help with Journal to edit object display on solid bodies
CODE -->
Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_solid_type .Subtype = 0 .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End With response = ui.SelectionManager.SelectObjects(message, title, scope, _ selectionAction, includeFeatures, _ keepHighlighted, selectionMask_array, _ selectedObjects)Not sure if this is the best method? But it works!
Thanks anyway!
