Ring Stiffner Need
Ring Stiffner Need
Can someone tell me when we have to use ring stiffeners??. Iam checking the previous projects, where they had used internal ring stiffeners in Cylindrical legs of tubular members for jackups.
Does API says anything related to need for ring stiffener?? Is it related to Geometry? Also, if we are using the stiffener do we need to check the strength ?? If so, what kind of loads?? (hydrostatic...??)
Thanks for the help..
RE: Ring Stiffner Need
API RP 2A and ISO 19902 are useful references for you. They give you guidance for sizing and spacing rings stiffeners to prevent hydrostatic collapse and methods for assessing ring stiffened tubular joints.
