API650 Frangible Joint
Hi everybody
My question is the next one:
Is it true that frangible joint is only use for tanks in which internal pressure doesn´t exceed the weigth of the roof?
I am asking because I am about to design a tank with working pressure= 8 in H2O. About this pressure, what should be the design pressure?
Thanks in advance,
Thanks in advance,
RE: API650 Frangible Joint
So, if the tank does not have frangible joint. Can I specify any permissible detail of compression ring in figure F-2?
