Edit attribute without open NX files
it's possible via programming to create or delete or edit NX attribute without open the files ?
If yes, which is the code or the command to use ?
Thank you...
Using NX 8 and TC9.1
RE: Edit attribute without open NX files
(from the T-docs)
UF_ATTR_ask_part_attrs_in_file
Defined in: uf_attr.h
Overview
Reads all the part attributes from a part file without requiring that the
part be opened. The values returned are always those stored on disk
even if the part is currently loaded in memory (use
UF_ATTR_ask_part_attrs for such a part). This routine is normally
considerably more efficient than opening the part and finding the part
attribute.
Environment
Internal and External
See Also
UF_ATTR_part_attr_s
Required License(s)
gateway
int UF_ATTR_ask_part_attrs_in_file
const char * part_name,
int * n_attributes,
UF_ATTR_part_attr_p_t * attributes
const char * part_name Input Part file name to read part attributes from or
part name when using NX Manager (internal name).
int * n_attributes Output Count of attributes returned.
UF_ATTR_part_attr_p_t * attributes Output to UF_*free* Allocated array of structures holding
attribute titles and values. This must
be freed by the caller using UF_free.
If a returned attribute type is UF_ATTR_string or
UF_ATTR_reference then the string returned
was dynamically allocated and you must use
UF_free to deallocate the memory.
If a returned attribute type is UF_ATTR_time, then
the value will be in the current time zone of the
machine on which the program is being executed.
