influence factor If for immediate settlement computation
Anyone have the equation for the depth factor If from Bowles (immediate settlement computation). Id like to make a spreadsheet but with only a graph, it's a lot harder. From an old thread, I know the equation is from Fox (1948)and some people had it (a long time ago). Anyone still have this paper?
thanks in advance
thanks in advance
RE: influence factor If for immediate settlement computation
Also, the recent embedment correction factor from Mayne And Poulos, 1999 is simpler and just fits perfectly into a spreadsheet.
Thanks in advance
Jerome
Mayne, P.W. and Poulos, H.G. (1999). Approximate displacement influence factors for elastic shallow foundations. ASCE
Journal of Geotechnical & Geoenvironmental Engineering 125 (6), 453-460.
however, does anyone have any ideas on how to average out the different results from the center point and the corner points?
I'm not sure about the need to average the values. Das in his book 'shallow foundations' gives a couple of averaging relationships but that way we loose precious information, that is the fact that we have X inches settlements at the center and Y inches settlements at the corners, usually with X>Y, is something we should be well aware of (differential settlements). As far as I recall, starting with the t rigidity factor and the foundation's elastic modulus Mayne's method yields both center and corner settlements, if they are about the same, then the foundation is rigid, otherwise it is not and settlements are different and averaging would just obscure the difference in an more or less optimistic way.
I might have misunderstood your question though...
I too would appreciate a copy of the fox equation (1948). My email address is ahmad.jomezadeh@gmail.com. Thanks for your time and consideration!
From my understanding there is no need to average out between corner and centre (I may be wrong !).
I started a spreadsheet according to the paper, if anyone wants to have a look they are welcome.
If possible, get a copy of it to my email.
Many thanks
I am sending spreadsheet to your email.
Please let me know how you go with it.
