Checking holes perpendicularity
I want to know if the axis of a drilled hole is perpendicular to the plate edge. What are 'indstrial tools" that exists to perform this measurment?
RE: Checking holes perpendicularity
Mike Halloran
Pembroke Pines, FL, USA
Han primo incensus
I fully understand WHY You said "Never use a drill bit for a pin gage, use a pin gage and an accurate square"...
However If You could explain this to "all others" it would be helpful (I haven't got the time).
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Also, because you do not have continuous periphery on the lands and margins of a drill bit with which to fully contact the sidewalls of the hole being checked. Threaded rods, pencils, bolts, cigarettes, and that left-over dried-up french fry you found under the bench are also verboten.
Point being, use the correct tool for the job.
CAUTION. Inserting the razor-sharp-flutes of a drill/reamer-bit into a hole is guaranteed to produce length-wise bore scratches, which can grossly shorten fatigue-crack initiation time and reduce the overall fatigue-life of the assembly.
NOTE. Inserting the shaft-end [smooth-end] of the drill/reamer-bit into the hole may work "OK", assuming that the shaft is burr-free. HOWEVER, IF the shaft is burred [IE: due to drill-chuck scoring], then the burrs will also score the hole walls, same as the drill-bit flutes.
Best plan is to use go/no-go hole pin-gages with a perpendicularity check-block.
Regards, Wil Taylor
Trust - But Verify!
B.E.
Most machine shops use photographic imaging for best dimensional measurement accuracy.
?I'd guess image analysis might answer your question. Would take some effort tho.
