Chiller Pipe Design
Chiller Pipe Design
Hi Everyone,
I am just starting my career in the MEP design world. I was previously involved in research and development. I need advice on two topics:
1) What is the best method for sizing pipe in a chiller system (process chilling)? And what method do you use for sizing pipe in a residential plumbing system?
- Extra info: I already have the chiller sized and a required header of 4" SCH40 PVC. I'm looking at branching off of the header to 5 different lines requiring a total of 25 GPM each with 3 sets (supply/return) of 2" drops on each branch. I'm curious as to how to size the branch. I assume I need to calculate equivalent length and use the chart with pressure loss vs gpm but I'm unsure of how to calculate pressure loss. Can I calculate my start pressure (from pump) from the GPM and head? Thank you for allowing me to ask the easy questions.
2) What references do you suggest as I try and teach myself as much as possible...I'm currently working for a very busy, small MEP design shop so I need to teach myself as much as possible.
Thank you in advance for your help!
RE: Chiller Pipe Design
The ASHRAE fundamentals book will tell you a lot on the details.
Application of B&G products has been a building block in our MEP industry. I can solve 90% of designs issues with a Trane ductulator and a B&G system sizer. Carry both with you. Application of the correct velocity for the type of pipe/application is the key. Welcome to the industry. Steve.
