angle based pressure loading
i am doing analysis of pressure vessel in femap, for that i need to give a angle based pressure loading equation, is it possible in femap...
RE: angle based pressure loading
do you mean a non-uniform pressure loading (that changes with angle) ?
Quando Omni Flunkus Moritati
yes
Dear Magesh2300,
You need to define a LOCAL COORDINATE SYSTEM and then apply a variable pressure using METHOD=VARIABLE, and define the equation of variation. Here you are a tutorial with the steps:
http://www.iberisa.com/soporte/femap/presion_varia...
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
