Feature Parameter Dimensions style?
thread561-272960: Inherit Feature Parameters: how to change Arrow Style automatically
I have the same problem that was started in this thread. All user created dimensions are solid filled but feature parameter dimensions are open arrows, what to I need to change so they match the filled arrows automatically so we don't have to change them manually every time?
RE: Feature Parameter Dimensions style?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I'm having the same problem, except not only are the feature parameter dimensions open arrow, they are also a different font than the user created dimensions. I have checked my "Annotation Preferences" and they are consistent with my user created dimensions, since having the "Use sketch dimension style" check-box un-checked should use the "Annotation Preferences" defaults, right? I am running NX 7.5, any help would be appreciated
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
- Open the template part itself, Preferences - Annotation, check the arrow settings, then press "load defaults" - OK and save the part.
try create a new part and see how the arrows appears.
Tomas
