damping devices
damping devices
damping devices
I want to know the use of viscous damper and tuned mass damper. Please expalin the function and the difference in the application of the two.
RE: damping devices
I suggest you look for texts written on London's Millenium Footbridge (designed by Sir Norman Foster & Arup).  The excessive vibrations on this bridge have been cured using dampers and this should give you what you're looking for.
Andy
