Typical Mils Vibration Question
Can mils be a positive and a negative number? I've seen positive all the time. However by my operators rounds and readings, they are reporting negative. If I have a trip/alarm setpoint of (5/10)-mils for compressor vibration on a chiller, does that typically account for both magnitudes?
RE: Typical Mils Vibration Question
However when describing thrust (axial) position of shaft, one might use negative number.
(2B)+(2B)' ?
