Moldwizard spreadsheets
I have been getting some errors when I change a standard part with MoldWizard. I am using 7.5.5.4 on a Windows 7 platform. We use Excel 2010 as well, but I have noticed that when I look at the spreadsheets that have been copied from previous versions of NX I notice that they are running in compatibility mode. The extensions are all .xls. Should I open each one up individually and convert it to a .xlsm? I would also have to change the registry spreadsheet in MoldWizard if I did. Is this a good idea? The error I have been seeing is the error "Cannot find record..." and then it lists the name of a variable that is on another sheet in the Excel file.
Anyone have any ideas?
