Overhead Crane Tractive/Longitudinal Force
I am looking at AISC Steel Design Guide 7 example 18.1.1. They show that the longitudinal/tractive force is 10% of max vertical load per wheel. Then as you look into the design guide the bumper force is 2x the tractive force.
The question I have per my example if this seems correct:
Say (2) 30 ton overhead cranes in a crane bay with max wheel load of 42k
-Longitudinal/tractive load= .1*(42k/wheel)
=4.2k/wheel
= 16.8k (total due to 2 wheels per crane)
- Bumper force=2*(tractive force)
=2*(16.8k)
=33.6k
Thus the final crane x-bracing to be designed for is due to a maximum horizontal force parallel to runway equal to 33.6k.
Do you typically only design the crane wall braces for longitudinal/tractive forces or do you have to design for the the maximum bumper force.
=4.2k/wheel
=2*(16.8k)
=33.6k
RE: Overhead Crane Tractive/Longitudinal Force
Hence, I think the bracing should be designed for the 16.8 kips.
Mike McCann
MMC Engineering
