Teamcenter export
Teamcenter export
Teamcenter export
I need to create a zip file which would include a drawing file, its assembly and the components of the assembly (all these NX files created and located in Teamcenter).
How could I do this task, I haven't ever done it so far (never created/exported a zip folder frrom Teamcenter)........
MZ7DYJ
RE: Teamcenter export
You could use file export assembly out of teamcenter. In the naming tab turn you export name to autotranslate. Then look at all of the other tab options. Click on the main tab and click on the add assembly. Yes I know add assembly you can do your drawing and associative components. This will kick you into teamcenter. Select your drawing that is attached to your assembly. Then Click Execute. Oh I forgot under the name tab make sure you set a good export to dircetory.
Thanks SDETERS!
MZ7DYJ
