Wavelinked Geometry Management Recommendations
With regards to the wavelinked part in the parent , what is the best way to manage it.
Alot of people have said that after creating the wavelink, the child part should be suppressed, However i have also heard that it should be hidden and put on a different layer from the work layer (Either way, it needs to be removed from the parent reference set)
Having experienced both methods, I have still found problems when updating the child.
After opening the parent, the child does not automatically update (IS there a feature that will force an update)
Sometimes i have found that even though the child has been updated, the geometry the wavelink is looking at is still out of date).
What are peoples recommendations for controlling and managing wavelinks to get the most efficent update?
NOTE:
When refering to child part, im meaning the casting
When refering to the parent part, im meaning the machining (removal of material from the casting)
NOTE:
RE: Wavelinked Geometry Management Recommendations
NX 7.5.5.4 MP09.
We only hide the casting for clarity reasons, ie to make sure we are removing material from the wavelinked geometry and not the part (although it wont let you select the part anyway. Because the "model" ref set only contains the machined part, this is what appears in the drawing and when added to any assemblies
I will try things using your method and see if it clears the problem.
Thanks!
Having the assembly load options set to partial loading "on" and load interpart to "none", could also prevent the update from occurring.
HTH,
Joe
