Project curves
Project curves
can you project curves away from a point onto a surface?
RE: Project curves
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Project curves
Thanks.
RE: Project curves
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Project curves
CODE -->
' Journal to project lines from a point to a datum plane Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Module ProjFromPointToPlane Dim s As Session = Session.GetSession() Dim ui As UI = ui.GetUI() Dim ufs As UFSession = UFSession.GetUFSession() Sub Main() Dim wp As Part = s.Parts.Work PointStart: ' select a point Dim pnt1 As Point = Nothing Dim response1 As Selection.Response = Selection.Response.Cancel response1 = select_a_Point(pnt1) If response1 = Selection.Response.Back Then GoTo End1 If response1 = Selection.Response.Cancel Then GoTo End1 Dim pnt0 As Point3d = pnt1.Coordinates DatumStart: Dim dplane1 As DatumPlane = Nothing Dim response2 As Selection.Response = Selection.Response.Cancel response2 = selectDPlane(dplane1) If response2 = Selection.Response.Back Then GoTo PointStart If response2 = Selection.Response.Cancel Then GoTo End1 Dim response3 As Selection.Response = Selection.Response.Cancel CurvesStart: ' datum plane normal Dim dplanenormal1 As Vector3d = Nothing Dim dplaneorigin1 As Point3d = Nothing dplanenormal1 = dplane1.Normal dplaneorigin1 = dplane1.Origin ' should check that datum plane normal is directed towards the point ' and that the projection is possible. This is not implemented ' select a line to project Dim line1 As Line = Nothing Dim startpnt As Point3d = Nothing Dim endpoint As Point3d = Nothing Dim vec1 As Vector3d = Nothing Dim uvec2 As Vector3d Dim vec2 As Vector3d Dim sub1 As Double = Nothing Dim sub2 As Double = Nothing Dim param1 As Double = Nothing Dim dplanepnt1 As Point3d = Nothing Dim dplanepnt2 As Point3d = Nothing Dim line2 As Line = Nothing curvesContinue: response3 = select_a_line("Select line to project", line1) If line1 Is Nothing Then GoTo End1 ' Get line endpoints startpnt = line1.StartPoint endpoint = line1.EndPoint ' project each point to datum plane ' startpoint vec1 = SubtractPoint3d(dplaneorigin1, pnt0) vec2 = SubtractPoint3d(startpnt, pnt0) uvec2 = UnitizeVector(vec2) sub1 = Dot(dplanenormal1, vec1) sub2 = Dot(dplanenormal1, uvec2) param1 = sub1 / sub2 dplanepnt1 = AffineComb(pnt0, param1, uvec2) ' endpoint vec2 = SubtractPoint3d(endpoint, pnt0) uvec2 = UnitizeVector(vec2) sub2 = Dot(dplanenormal1, uvec2) param1 = sub1 / sub2 dplanepnt2 = AffineComb(pnt0, param1, uvec2) ' now create line line2 = wp.Curves.CreateLine(dplanepnt1, dplanepnt2) GoTo curvesContinue End1: End Sub Public Function SubtractPoint3d(ByVal p1 As Point3d, ByVal p2 As Point3d) As Vector3d Dim v1 As Vector3d v1.X = p1.X - p2.X v1.Y = p1.Y - p2.Y v1.Z = p1.Z - p2.Z Return v1 End Function Public Function UnitizeVector(ByVal v1 As Vector3d) As Vector3d Dim v2 As vector3d Dim length As Double = math.sqrt(v1.x * v1.x + v1.y * v1.y + v1.z * v1.z) v2.x = v1.x / length v2.y = v1.y / length v2.z = v1.z / length Return v2 End Function Public Function SubtractVectors(ByVal v1 As Vector3d, ByVal v2 As Vector3d) As Vector3d Dim v3 As Vector3d v3.X = v1.X - v2.X v3.Y = v1.Y - v2.Y v3.Z = v1.Z - v2.Z Return v3 End Function Public Function Dot(ByVal v1 As Vector3d, ByVal v2 As Vector3d) As Double Return v1.X * v2.X + v1.Y * v2.Y + v1.Z * v2.Z End Function Public Function AffineComb(ByVal p1 As Point3d, ByVal s As Double, ByVal v2 As Vector3d) As Point3d Dim p2 As Point3d p2.X = p1.X + s * v2.X p2.Y = p1.Y + s * v2.Y p2.Z = p1.Z + s * v2.Z Return p2 End Function Function selectDPlane(ByRef object1 As DatumPlane) As Selection.Response Dim selectionMask_array(0) As Selection.MaskTriple selectionMask_array(0).Type = UFConstants.UF_datum_plane_type selectionMask_array(0).Subtype = 0 selectionMask_array(0).SolidBodySubtype = 0 Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject("Select a Datum Plane", "Select a Datum Plane", _ Selection.SelectionScope.WorkPart, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, selectionMask_array, object1, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok ElseIf resp = Selection.Response.Back Then Return Selection.Response.Back ElseIf resp = Selection.Response.Cancel Then Return Selection.Response.Cancel Else Return Selection.Response.Cancel End If End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function Function select_a_Point(ByRef pnt1 As Point) As Selection.Response Dim mask(0) As Selection.MaskTriple With mask(0) .Type = UFConstants.UF_point_type .Subtype = 0 .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject("Select point to project from", "Select a Point", _ Selection.SelectionScope.AnyInAssembly, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, mask, pnt1, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Public Function select_a_line(ByVal prompt As String, ByRef line1 As Line) As Selection.Response Dim mask(0) As Selection.MaskTriple With mask(0) .Type = UFConstants.UF_line_type .Subtype = 0 .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject("Select line to project", "Select a line", _ Selection.SelectionScope.WorkPart, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, mask, line1, cursor) If resp = UFConstants.UF_UI_OBJECT_SELECTED Or _ resp = UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then Return resp ElseIf resp = Selection.Response.Back Then Return Selection.Response.Back Else Return Selection.Response.Cancel End If End Function End ModuleRegards
Frank Swinkels
RE: Project curves
Frank Swinkels
RE: Project curves
How would I add the ability to pick splines to the journal?
What software are you using to write the journals with?
