How to open a Drawing from the Model
Hi All,
Please help me to find a way to reach model from a drawing, the reverse side is so easy (Just D'Click on any view).
Thanks in advance
Thanks in advance
RE: How to open a Drawing from the Model
--Scott
www.wertel.pro
Also is there a global scale factor for the Hatch spacing (to change hatch spacing for all materials and in all views of a sheet)
Ken G.
http://grundey.blogspot.com
These are file based so if you do it in your template files it would appear in all new files.
Existing ones would not be affected.
Existing files would have to be done individually, but you could use the styles organiser to copy in the new style definitions.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
