intresting brick lintel installation idea to existing
http://www.diversityproducts.co.uk/NO-MORE-PROPS-B...
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
RE: intresting brick lintel installation idea to existing
1. Is it available in the US?
2. What is the item cost for the masonry contractor?
3. What is the maximum lintel span/load that can be accommodated?
4. Is the product designed based on a triangular load distribution from the masonry, or a more conservative uniform load distribution?
5. Is there a limit to the masonry wall thickness?
6. How much bearing is needed at each end?
Mike McCann
MMC Engineering
They do look like pretty clean and clever devices. They probably do save some time and effort, even though they are not the only way to do it.
