Viewing results-different viewports
Hello everyone,
I have three viewports in ABAQUS viewer, i need to compare them.
The problem is:
the same color has different range of values for different viewports, for instance in the first viewport, the red color represents a stress ranges from 1000-1100, while in the second viewport, the same color (red) represents a stress ranges from 900-1000, and in the third viewport, the same red color has difernt range.
So how can i make the same color has the same range of values for all viewports? I guess this will make comparison much easier
The problem is:
RE: Viewing results-different viewports
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
To set user min and max values for your countor plots go to:
Options -> Countor -> Limits and specify min and max values.
If you are going to compare couple models linked viewports is very helpful.
Viewport -> Linked viewports
Bartosz
