NX6 pdf printing issue
I am having an issue when I try to create a pdf file of our drawings. I can go to File>Export>PDF and the file comes out fine, except the fonts are different from what we're using on our drawings. However, when I try to create a pdf file by clicking on the "Print" icon or clicking on File>Print, the drawing comes out on an 8 1/2 X 11 sheet. I created a sheet size so the drawing should print properly, but the pdf comes out with a lot of white space above and below the drawing. I've attached pics of the pdf settings. I hope that helps.
Thanks for your help,
Al
Al
RE: NX6 pdf printing issue
We're using NX 6.0.0.24 on Windows 7, 64bit.
Thanks again!
Al
www.nxjournaling.com
