A394 & A325
A394 & A325
Can anyone tell what the major difference is between A394 and A325. They have the same tensile and shear strength, can we use A325 for tower bolts?
RE: A394 & A325
If you have larger angles you can use the A325, but if you have 2x2x3/16 or smaller, the A325 bolt head is large enough to be too close to the fillet of the inside of the angle. Take a look at the bolt dimensions to see what I am talking about.
_____________________________________
I have been called "A storehouse of worthless information" many times.
RE: A394 & A325
Because I am so used to A394 Type 1, I never bothered to compare the geometrical details until recently I had a situation where the A325 was being used when the connection is under TENSION. If A394 & A325 have the same nut, they should have the same tensile property as well. So why under tension, we use A325?
RE: A394 & A325
I am only guessing, but with the larger bolt head of the A325, the tension capacity may have more safety factor with the larger head. Also the A394 typically does not use washers while I think the A325 uses them to get a better clamping force for the torque input.
RE: A394 & A325
It's true tower bolts are predominantly under shear, but we use pretty tight clamping force. We use lock washer (helical spring) to secure the bolt and nut. The torque is 90 for 5/8 and 120 for 3/4
RE: A394 & A325
We used to buy bolts and nuts separate in 2 boxes of about 25 pounds. I joke about our crews that they would make up a connection and pour out the box of bolts onto the holes and the ones that went in the hole would get a nut installed and the rest of the bolts were left on the ground so when it god muddy, they would have something to walk on.
We don't use any lock washers or washers (except on wood H-Frames to combat wood shrinkage) and just paint the threads after assembly. For a while we tried ZEP (zinc electro plated) bolts and nuts but went back to galvanized when the ZEP did not hold up in our hot and wet climate (South Texas gulf coast).
RE: A394 & A325
What if some lunatics or punk kids steal the bolt for fun? If the clamping force is too low. They would be able to remove the bolt with regular wrench ...
Just some thoughts ...
RE: A394 & A325
My own PSA: For those unfamiliar with the T-Line industry reading this thread, the wires are not insulated. They will kill you if you even get close (within 10' for 345kV) under ideal conditions. As they transmit power, the conductors get very hot and sag down with thermal expansion. We run them at hot as 250°C under an emergency. This is why you don't see many birds sitting on the conductor because it burns their toes and the E-Field on their feathers makes them not like it either. We count on the wind blowing over the bare wire to transfer heat away. The big blackout in the Northeast a few years ago was due to a T-Line sagging into some trees underneath. This tripped the circuit and the power tried to roll to other lines which quickly overloaded and tripped out. The cascading failures put several states in the dark.
RE: A394 & A325
RE: A394 & A325
RE: A394 & A325
RE: A394 & A325
RE: A394 & A325
