B31.3 - Heat Treatment
Hello friends, greetings. I need help.
I have a weld metal with base P No. 1, that the throat is 17.0 mm, in accordance with paragraph 331.1.3 (b) (1) of the code ASME B31.3, where the temperature should be used?
RE: B31.3 - Heat Treatment
http://www.weldinguide.com/gdanastasiadis/viewtopi...
