Arcing when closing line switch
I had the opportunity to watch a 230 kV line switch closing to tie the 230 kV line to the new substation that was built for a 230 / 13 kV substation which was energized. I noticed that when the switch was closed, there was arcing as the switch was being closed. Is this arcing normal or is there something wrong? The arc has a current of approximately 3 A.
RE: Arcing when closing line switch
"Will work for (the memory of) salami"
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
http://www.youtube.com/watch?v=GMbN9nb3qyk
Best to you,
Goober Dave
Here's one that illustrates what I said about closing a switch. Although the extreme voltage makes it more dramatic and noticeable, this happens at some level with every switch, regardless of voltage.
Video of 138kV switch CLOSING
