Any quick method to estimate MCSF in different speed?
I have a pump with VFD. Currently the vendor provided the MCSF on a pump curve at a rated speed.
I am just thinking if there is a quick method I can estimate the MCSF at different speeds? similar as affinity law?
Thanks.
Thanks.
MSc. Mechanical Engineering;
5 years EPC experience;
Oil & Gas industry in Canada.
RE: Any quick method to estimate MCSF in different speed?
Independent events are seldomly independent.
MCSF is determined by maximum permissible temperature rise in the pump. This number typically comes from pump manufacturers empirical data.
The old equation for Temperature rise in a pump (don't know why a new one would be any better) is:
Temp Rise, DegF= (TDH,ft./778) * ((1/Efficiency at point considered) - 1)
If a manufacturer of a certain pump says the max permissible temp rise is 20 degrees, then you can backcalculate your minimum flow using the performance curve.
Not that I am aware of, however lacking any further detail I would draw a line from the MCSF given by the manufacturer at the rated speed to the 0,0 point of the H/Q graph and use that as a guide. Bear in mind as you slow the pump radial loads on the shaft see a rapid reduction and hydraulically, without testing at all speeds and reduced flows the MSCF becomes guess work.
