colorbar interval
colorbar interval
colorbar interval
Hi
I've following problem;
I've two colorplots with tension values on a surface. Is there a possibility to make the colorbars with the same color interval?...with i.e. the green color on point 0 but with a different range i.e [-2000 1000] for the left and [-10000 0] for the right plot. So the scale and colorinterval should be the same.
Thanks in advance!
