Laser Cutting Aluminum
We have a 2000 watt Mitsubish Laser, we cut ss. Alu and steel. on aluminun we use sheet with a laser film. On the thinner materials this works fine. On 3/16" and thicker, it bubbles or blows the paper. Are there conditions we can use so this does not happen. Our alternative is to use dish soap on the material, this is not cost effective.
RE: Laser Cutting Aluminum
If that doesn't help, you need to preburn the plastic on the whole cutting profile (low power, cutting head higher above the plastic) so it will stick to the alu. Your programming software or a machine option should allow you to do that.
O9006(PVC-STAINLESS-PRCE)
M199M80
S500T1000M86G4X.1
M87
M98P9009
M99
O9009(THIN-NO-SPOON-LIF)
M101M198
M120
M#501M99
