Minimum Interpass Temp
In multipass welding what is minimum interpass temperature
Pandithan
RE: Minimum Interpass Temp
The preheat temperature unless something else is indicated in the WPS.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Correct, it is the minimum preheat temperature as stated in the WPS.
ASME WIII div. 1 gives values in appendix. They are the maximum.
