threaded rods
threaded rods
i am looking for a .250-28 unjf-3a threaded rod.
does anyone know where I can buy this?
I only need about 3 feet
thanks,
Phil
thanks,
Phil
RE: threaded rods
Mike Halloran
Pembroke Pines, FL, USA
RE: threaded rods
RE: threaded rods
i don't need a continuous thread but at least 2" thread on each end. i found a shop near me that could do it but expensive for this type of thread.
RE: threaded rods
RE: threaded rods
Mike Halloran
RE: threaded rods
UNJF implies a sophisticated strength requirement. Do You need any of the following?
Rolled threads... or are cut threads OK (flight critical [fatigue] VS non-critical [static]?).
RH turn thru the length... or LH turn one end; RH turn opp end?
Alloy/strength? Carbon steel, LA steel, CRES? 95, 125, 140, 160, 180, etc -KSI?
Min weight design required? IE enlarged threads with a smaller diameter straight section blended-in-between?
Examples of what is available for aircraft [UNF not UNJF]
AN704 Tie-Rod Internal 3,400Lb (1/4-28)
NAS1454 Rod, Continuous Thread
Perhaps this concept would work better...
NAS363--369 Control Rod and Tube Assy 1/4-28UNF-3A Thread
Otherwise, You may be better-off designing what You need
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
