600v Wire tension
600v Wire tension
I have a switchgear lineup on a concrete pad that is on piers, and runs 100' to the building with 4 sets of 500 kcmil. The switchgear is moving. How could I determine how much it can move before something dramatic happens?
100' seems like it could take some movement
RE: 600v Wire tension
This can be compared to the maximum allowable tension for the given wire type or support messenger. In addition, you can add snow/ice loading and wind loading (if applicable).
