Blanket gas PVC design
I'm designing a PVC for tank blanket gas, total flow is 250m3/hr. should I design PVC for hundred % flow or less. Flow through RO is 250m3 /hr at1psig.
10815l
10815l
RE: Blanket gas PVC design
I think You mean a PCV?
You must design for 100% or more, otherwise You can create a vacuum
The control valve regulates the flow.
10815l
10815l
