Heat Treat Stainless - Bench Oven/Furnace
Hello!
I am in need of some advice for heat treating small batches of stainless steel components. I currently own a Thermo Oven ( http://www.labdepotinc.com/Product_Details~id~93~p... ), but this one doesn't have enough horse power to perform the H900 or H950 on more than 5 pounds 17-4 or 455 stainless.
Has anyone used a mid-sized oven and/or can recommend one? I'd like to be able to do about 20-30 pound loads.
I've looked at these ovens too, but the ramp time (unloaded) is 90 minutes! http://www.grievecorp.com/catalog/Batch-Ovens/High...
I believe a good practice is to ramp within 45-60 minutes, is this correct? (ASTM A564 Age-hardening standard )
Any thoughts or comments on the oven or heat treat process are welcome. I've done my research but I still feel like a bit of a novice.
Thanks!
Thanks!
RE: Heat Treat Stainless - Bench Oven/Furnace
Remember that you need to be able to do furnace surveys and run load thermocouples, if you care about the results.
Plymouth Tube
