Interactive Indication of a 3D point on curve or on surface
I'm working on to get a user input as follows.
User has to indicate two points to measure distance (on curve, or on surface/face) inside a part document.
I'm in a bit of dilemma with the API's in documentation.
Could somebody guide me on this or perhaps with a code to achieve the same.
Taking this as an input i need to measure the distance between two points on a curve.
Maddy
Maddy
Maddy
The willingness to share knowledge does not make one charitable; it makes one self-reliant to know more.
Modified - Courtesy of Robert Brault
RE: Interactive Indication of a 3D point on curve or on surface
CODE --> CATScript
Sub CATMain() Dim oDoc As Document Set oDoc = CATIA.ActiveDocument Dim oSel As Selection Set oSel = oDoc.Selection Dim oPart As Product Set oPart = oDoc.Part Dim oHybridBodies As HybridBodies Set oHybridBodies = oPart.HybridBodies Dim oHybridBody As HybridBody Set oHybridBody = oHybridBodies.Add() oHybridBody.Name = "User Selected point" oPart.InWorkObject = oHybridBody oPart.Update Dim oHSF As HybridShapeFactory Set oHSF = oPart.HybridShapeFactory Dim oInputObjectType() Dim iStatus As Integer ReDim oInputObjectType(1) oInputObjectType(0)="TriDimFeatEdge" oInputObjectType(1)="BiDimFeatEdge" iStatus = oSel.SelectElement2(oInputObjectType,"Select an edge ",FALSE) If (iStatus = "Cancel" Or iStatus = "Undo" Or iStatus = "Redo") then Exit Sub Dim oEdgeOrCurveSelected Set oEdgeOrCurveSelected = oSel.Item(1).Value 'Dim s 's = TypeName(oEdgeOrCurveSelected) & vblf & vblf 's = s & TypeName(oEdgeOrCurveSelected.Parent) & vblf & vblf 's = s & oEdgeOrCurveSelected.Parent.Name & vblf & vblf 's = s & TypeName(oEdgeOrCurveSelected.Parent.Parent) & vblf & vblf 's = s & TypeName(oEdgeOrCurveSelected.Parent.Parent.Parent) & vblf & vblf 's = s & TypeName(oEdgeOrCurveSelected.Parent.Parent.Parent.Parent) & vblf & vblf 's = s & TypeName(oEdgeOrCurveSelected.Parent.Parent.Parent.Parent.Parent) & vblf & vblf 's = s & TypeName(oEdgeOrCurveSelected.Parent.Parent.Parent.Parent.Parent.Parent) & vblf 'MsgBox s iStatus = MsgBox("Please Select Point 1",VbOkOnly,"Point 1") If iStatus = vbCancel Then Exit Sub ' Following has been taken from documentation ' **************************** ' See also: Selection.IndicateOrSelectElement3D which can, in particular, 'enable indication and not selection (positionning the iFilterType parameter 'to an empty string), whichs enables to subscribe to mouse move events, 'positionning the iTriggeringOnPreSelection to true. ' **************************** Dim HybridShapeFactory Dim InputObjectType(0) Dim WindowLocation2D(1) Dim WindowLocation3D(2) Dim TempPointHasBeenCreatedAtLeastOnce Dim ObjectSelected Dim ExistingPoint Dim PlaneReference ReDim WindowLocation2D(1),WindowLocation3D(2) InputObjectType(0) = "" Set HybridShapeFactory = Part.HybridShapeFactory : Set Body = Part.Bodies.Item("PartBody") 'Set HybridShapePlane = Body.HybridShapes.Item("Plane.1") Set HybridShapePlane = Part.OriginElements.PlaneXY Set PlaneReference = Part.CreateReferenceFromObject(HybridShapePlane) ' Empty string - through filter array iStatus = oSel.IndicateOrSelectElement3D(HybridShapePlane,"select a point or click to locate the point", _ InputObjectType,false,false,true, _ ObjectSelected,WindowLocation2D,WindowLocation3D) ' Not working ' Empty string - Direct iStatus = oSel.IndicateOrSelectElement3D(HybridShapePlane,"select a point or click to locate the point", _ "",false,false,true, _ ObjectSelected,WindowLocation2D,WindowLocation3D) ' Not working ' This selects the existing point. InputObjectType(0) = "Point" iStatus = oSel.SelectElement3(InputObjectType,"Select points", _ true,CATMultiSelTriggWhenSelPerf,false) End SubSame way, is it Possible to get 3D Coordinates i.e X,Y,Z. Indicated 3D option does mention about the same i suppose.
Can you guide me on this.
Maddy
Maddy
CODE --> CATScript
Sub CATMain () Dim Was1(0) Was1(0) = "Point" Dim UserSel As Selection Set UserSel= CATIA.ActiveDocument.Selection UserSel.Clear Dim E As CATBSTR E = UserSel.SelectElement2(Was1, "Point", False) If E = "Normal" Then FirstPoint = UserSel.Item(1).Value.Name MsgBox FirstPoint Else MsgBox ("Abort") End If UserSel.Clear ' -------------------------------------------- Dim Was2(0) Was2(0) = "Point" Dim UserSel2 As Selection Set UserSel2= CATIA.ActiveDocument.Selection UserSel2.Clear Dim F As CATBSTR F = UserSel2.SelectElement2(Was2, "Point", False) If F = "Normal" Then SecondPoint = UserSel2.Item(1).Value.Name MsgBox SecondPoint Else MsgBox ("Abort") End If UserSel2.Clear ' -------------------------------------------- Dim documents1 As Documents Set documents1 = CATIA.Documents Dim pDocument1 As PartDocument Set pDocument1 = CATIA.ActiveDocument Dim part1 As Part Set part1 = pDocument1.Part Dim hybridBodies1 As HybridBodies Set hybridBodies1 = part1.HybridBodies Dim reference1 As Reference Dim hybridBody1 As HybridBody Set hybridBody1 = hybridBodies1.Item(1) Set hybridShapes1 = hybridBody1.HybridShapes Set reference1 = hybridShapes1.Item(FirstPoint) MsgBox ("ref1=" & reference1.Name) Dim reference2 As Reference Set reference2 = hybridShapes1.Item(SecondPoint) MsgBox ("ref2=" & reference2.Name) Dim TheSPAWorkbench As Workbench Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") Dim TheMeasurable As Measurable Set TheMeasurable = TheSPAWorkbench.GetMeasurable(reference1) Dim MinimumDistance As Double MinimumDistance = TheMeasurable.GetMinimumDistance(reference2) MsgBox MinimumDistance End SubRegards
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
@ferdo
http://www.eng-tips.com/viewthread.cfm?qid=252497
With reference to your post on below thread you have about CreateReferenceFromBRepName
' CreateReferenceFromBRepName( CATBSTR iLabel, CATIABase iObjectContext) As CATIAReference
Set reference1 = part1.CreateReferenceFromBRepName("RSur:(Face:(Brp:(AxisSystem.1;1);None:();Cf11:());WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", axisSystem1)
about Reference1
- i would like to know how, above is achieved (Underline One). (recorded i suppose)
- Is it possible to get this from selected edge of pad or a surface. (Could you give an example for clarity)
- i would like to create a point on the selected edge
- user has to indicate the point interactively.
need your assistance to get the code right which asks and grab the indicated point (similar to indicate2D)i.e he can indicate a point by clicking on selected curve apart from existing point / vertex
Maddy
@ ferdo,
Thanks for reply.
If the filter type is point / vertex then i don't have any issue in getting the coordinates.
But i'm working on is exactly similar to Indicate2D option where user clicks on drawing which gives back X,Y of point.
Same way here he has to click on curve he selected earlier. This is where i got stuck.
Documentation for Indicate3D mentions that
enable indication and not selection (positioning the iFilterType parameter to an empty string), whichs enables to subscribe to mouse move events, positioning the iTriggeringOnPreSelection to true.
Maddy
CODE --> CATVBA
Sub main() Dim Ergebnis As String Dim XZ(1), XYZ(2) ' As Double <== modification 1 Dim SelInd As Boolean Dim Filter(0) Dim Selektion 'As Variant <== modification 2 Dim coord(2) As Single Set partDocument1 = CATIA.ActiveDocument Set part1 = partDocument1.Part Set hybridBodies1 = part1.HybridBodies Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1") Set hybridShapes1 = hybridBody1.HybridShapes Set hybridShapePlaneOffset1 = hybridShapes1.Item("Plane.1") Filter(0) = "AnyObject" Set Selektion = CATIA.ActiveDocument.Selection Selektion.Clear Ergebnis = Selektion.IndicateOrSelectElement3D(hybridShapePlaneOffset1, "Auswahl", Filter, False, False, False, False, XZ, XYZ) If Selektion.Count <> 0 Then Selektion.Item(1).GetCoordinates coord MsgBox (coord(0) & " " & coord(2)) Else MsgBox ("X-eben= " & XZ(1) & ", Z-eben= " & XZ(0) & Space(15) & "X-3D= " & XYZ(0) & ", Y-3D= " & XYZ(1) & ", Z-3D= " & XYZ(2)) End If End Subindocti discant et ament meminisse periti
get the user to select the curve
indicate point with IndicateOrSelectElement3D and filter set to MonoDim (for curve)
get the 3D coordonate of the result
create 3d point with coordonate (it will be on plane from IndicateOrSelectElement3D and not on curve)
get direction normal to screen
project point to curve using direction
(if projection fail, user indicate on wrong curve)
split curve with point
compare length of split / length of curve
finaly build your point on curve using the ratio
delete all temp element: point(by coordonates), projection point, split.
I could not find a way to launch the command "point" with restriction to "on curve"
CATIA.StartCommand "Point" works but not exactly what you looking for.
Fernando
@Eric
Thanks for reply,
Will try to work on the points your said.
By taking only one point into consideration i.e. enable indication and not selection (positioning the iFilterType parameter to an empty string) i was working on to achieve as desired.
@ferdo or @Eric
Could you elaborate on
@ferdo
about Reference1
Maddy
AxisSystem.1;1 is the xoy plane of your CATPart origin and AxisSystem.1;3 is the xoz plane. They are created by default when you have the option ticked to insert an axis system when you start a new CATPart.
About references...I believe this link it will help you a little bit .
And bellow is how you can add a point on a curve (this is a specific case but you can get an idea how to do it in your case).
By the way, I'm really curios to see the code at the end.
CODE --> CATScript
Fernando
@Ferdo
Thanks for your code.
I'll upload the code once completed.
As of now i'm able to get the references of a selected edge (from Graphical Window) and pass on to create point
but yet to get the IndicateOrSelectElement3D option to work out.
Though this option is working results are not as per expected.
Maddy
