Need help!!, determining sump level in a distillation column
I am working on dynamic simulation and I am new to this work. can anyone give me an idea of how one can determine the sump height in a distillation column??? Please help!
RE: Need help!!, determining sump level in a distillation column
Is the column existing, or being designed? A drawing or sketch would help if you have it.
Good luck,
Latexman
No, It's a whole new process and I am trying to run it in Aspen. I need to design the column.
The first pass size is usually a residence time rule of thumb. For tower bottoms I recall 3-10 minutes, try 5 minutes and see how that works out.
Good luck,
Latexman
Design column bottom minimum 20 minute time,this practical approach. Keep in mind feed pump trip and other safety factors.
Cheers
10815l
