.sldSTD problem
.sldSTD problem
Today I consider the sldSTD a form of disease. For some reason I have never had my custom templates not use the existing standard I developed for 8 ½” X 11” drawings until SP3. I didn’t even know about the .SLDSTD template until today. My VAR has very little knowledge about this also.
I need to extract my old defaults from parts, assemblies and drawings to make my custom standard. How can this be done?
I have a folder with my default templates for SolidWorks and have put a .SLDSTD file in and have set the reference to look there but it still seems to revert to the ANSI standard. How do I make a custom standard file stick?
Ed Danzer
www.danzcoinc.com
www.dehyds.com
RE: .sldSTD problem
-handleman, CSWP (The new, easy test)
RE: .sldSTD problem
1-3795057238
SPR 714488 "'system option_file location_drafting standard' apparently doesn't produce any result"
1-3794224991
SPR 714486 "SW, opening old files, it is not able to show customized drafting standard as “ANSI/ISO etc.. –CUSTOMIZED”"
It will be interesting to see how long or if this is even addressed.For my small company the workaround is semi-painful and time consuming and actually affects about 30,000 files.
Ed Danzer
www.danzcoinc.com
www.dehyds.com
RE: .sldSTD problem
