Casing Spacers for HDPE Carrier Pipe in HDPE Casing
We have a project where we will need to provide a casing for a 12-inch water line that crosses under an irrigation canal. Because the canal is on the sideslope of a hill, the casing will have to have a curvature in it. The casing only needs to have the same strength as the carrier pipe, which will be HDPE DR-11. We have not bid this project yet and a number of contractors are inquiring into whether or not casing spacers are required. They are concerned that the ribs in the inside of the pipe that are formed in the fusion process will make it difficult to use casing spacers. They are proposing to use a 16-inch HDPE casing for the 12-inch HDPE carrier pipe without the casing spacers. This is the first time we have used HDPE as the casing pipe and would like any thoughts on the proposed method.
Thanks in advance for any advice.
RE: Casing Spacers for HDPE Carrier Pipe in HDPE Casing
Independent events are seldomly independent.
http://www.apsonline.com/pdf/CASING/CasingSpacers....
frauk11, we are the owner, not the contractor.
what did you fill the annular space with?
