NX 7.5 Polygon-shaped holes
I would appreciate any possible advice on the following issue:
I am attempting to design an object in NX 7.5 containing polygon-shaped "holes" that span from the top to the bottom surface. I've tried defining a polygon, extruding it such that it is located in the appropriate spot, but I am unable to subtract it from the body (ex. using Insert --> Combine --> Subtract). I also tried importing an extruded polygon and subtracting from the body that way, without any luck. I'm still becoming familiar with this software and may be missing a simpler way of doing this.
Thank you in advance.
RE: NX 7.5 Polygon-shaped holes
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you for your time.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
