Electric motor switch
My wife is an elementary school teacher and Ive agreed to help her with a project. They are putting on a play and need help with some stage props. They have a house and they want a cardboard cutout to move back and forth in a window. I have the basic idea of what I want to do and most of the materials. Im a machinist/engineer by trade so the design and fabrication aren't really the issue. I need help with the electrical stuff though. Basically what I plan on doing is taking a small electric motor and attaching a long threaded rod to the shaft. As the motor turns the shaft, the screw turns, and in so it will move the "nut" along the threaded rod. What Im having trouble with is when it gets to the end. I need it to come back and it would be great if I could make it pause before it changes directions. I would like to use a pressure switch at each end to change the direction of the motor rather than trying to do something with the timing. Any thoughts? Also, any suggestions on a motor? Id really like less than 10 rpms and it doesn't need a lot of torque or anything like that. Id like to be able to use around a 3/4" threaded rod on the shaft.
Thanks for any input.
RE: Electric motor switch
You can buy low rpm, low torque gearmotors from a variety of sources for under $50 or so, mcmaster.com has them (but not necessarily the cheapest option). If you need to reverse direction, you will need a dc version of them, again you can find them at mcmaster, or search for them. Surplus houses have them for cheap, but you may not find the exact speed/rpm you are looking for there.
A quick search found this switch. Its the style I was picturing in my head.
http://www.ebay.com/itm/TEMCo-Adjustable-Rod-Arm-L...
Any thoughts.
Connect to a battery.
Done.
Limit switch at end of travel that is actually a toggle switch to reverse motor polarity (see: useless machine). You could also have a kill switch at start position that will turn it off once it returns.
Pause when changing directions could be tricky if you want more than 1 second or so, but depending on slop in the gear box and the motor speed, you could achieve desired affect with just reversing the motor.
thanks
Will a toggle switch at each end reverse it back and forth? Im not trying to stop it either end and the pause isn't really necessary.
Everybody does :)
Look at some "useless machine" schematics. Basically a toggle switch on top of a box. You flip the switch, something comes out of the box to flip the switch back, the something reverses and goes back into the box, until you flip the switch again. That's all it does, so you can see where the name comes from.
Power supply, use a wall wart (whatever is lying around) and if necessary a potentiometer to reduce voltage and slow down/speed up the motor. Think wireless home (not cell) phone charger, rechargeable battery charger, pretty much anything that blocks more than 1 power outlet when you plug it in. Just read the fine print and it will tell you voltage and current.
Just a thought.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Last week of June. Any suggestions? Design or wiring
I dwelt on doing this electrically. Our friend btrueblood is correct, you can't really do that on the cheap. Assuming DC motor, I could work it with a DPDT alternating relay plus an interval timer relay, and two of your limit switches you found.
The alternating relay can reverse the polarity of the motor with each contact opening, so as your object hits the limit switch the motor will be stopped and the polarity reversed. But it won't start again by itself. At that point the inteval timer relay would wait a second or two, then short out your open limit switch contact to start the motor with the now-reversed polarity, and keep the contact closed until the object has time to move away from the limit switch and let it close. Same thing happens at the other end. You'd only need one interval timer relay.
You can pick up DPDT alternating relay on eBay for $25 or so, but the interval timer is going to be $50 plus and I didn't find any on eBay.
If it were for an educational program, my former company might donate a timer -- but I don't think they'd do that for a school play.
Best idea: ornerynorsk's. Only moving a couple feet across a window, a scotch yoke is ideal.
Best to you,
Goober Dave
The idea is that you have a power switch, when you turn it on the relay is deenergized and the motor goes in reverse
the moving thing eventually bumps the "forward" pushbutton, which energizes the relay and reverses the motor direction (forward). relay latches "energized" until circuit is broken.
the moving thing moves to the other end of the screw where it hits the "deenergize" button and the relay goes back to the original state and the motor again goes "reverse"
flip the power switch to stop.
sorry, no pauses - but you can always run the object past the end of the stage before it reverses, right?
You gave me a thought that your scheme might be fixable with a second relay -- but we still won't get the delay at the ends electrically. Your idea of just running the object out of sight at each end might do?
Best to you,
Goober Dave
You have a locking push button switch with 6 contacts on the bottom (dual pole, dual throw) that you use as a limit switch.
1-2-3
4-5-6
You jumper from 1-6 and 3-4
Power supply in goes to the middle: 2(+ wire) and 5(- wire)
You can wire the motor (or the center of another identical switch at the other end) to 1 and 4.
Toggle switch left (really a locking push button, but calling it toggle to illustrate the diagram)
2+ connects to 1 which is +
5- connects to 4 which is -
Motor turns clockwise
Toggle switch right
2+ connects to 3+ which is jumpered to 4, now outputs +
5- connects to 6- which is jumpered to 1, now outputs -
Motor turns counter clockwise
Every time a limit switch is hit, it flips the polarity and changes motor direction. If you have a switch on each end, the motor will change directions at each limit, and run back and forth all day. Add a main on/off power switch in front of all this stuff.
Maybe 10 bucks in wire and switches.
Alright, now somebody poke some holes in that idea!
The relay w/diode setup should also be around $10.
I'll volunteer a quick sketch (attached).
Best to you,
Goober Dave
What toggles either switch back to its normal position? I.e., what device, mechanical or electrical, resets the toggle/locking pushbotton switch to the "sense" mode after it switches polarity to reverse the motor? A push-and-stay locking pushbutton switch stays in the left-drive mode as the motor moves left, and suddenly hits the right hand switch - which now connects directly across the closed left switch - zap! Little brown star for you, to counteract the pink one you got...
Without latching relays it won't work, or you have to wire a single switch with a long mechanical hysteresis device to make it toggle as the motor drive nut swings from one side to the other, and that's not simple $10 stuff either. Latching relays can be made to do the job with momentary contact limit switches...but by the time you are done, you'll spend at least $50. Plus you still have to buy the motor.
SpecMFG, a window wiper mechanism is a pretty good analogy to what I was trying to describe earlier. An eccentric (crank, cam, whatever) drives a lever back and forth, the object could either be directly attached to the lever, or slide on a rail being pushed/pulled by a slider attached to the oscillating lever.
Bruteblood, I just don't see the "zap."
Here is the logic:
Power directly to motor would turn it CW, both switch 1 (S1) and switch 2 (S2) in position A turns motor CW
Power -> S1 A -> S2 A -> motor is CW, cutout moves to the right
Hits S2 right limit switch
Power -> S1 A -> S2 B -> CCW, cutout moves to the left
Hits S1 left limit switch
Power -> S1 B -> S2 B -> CW, moves to right
Power -> S1 B -> S2 A -> CCW, moves to left
Power -> S1 A -> S2 A -> CW, moves to the right
Rinse and repeat.
Goober Dave hit the nail on the head with the sketch.
Exactly like a ballpoint retractable pen in action. Push-click - one side goes ON, Push-click, other side goes ON. The button is always extended, waiting to be pushed.
The reset occurs the next time either switch is hit. Take a look at the attached.
I can use these diagrams in a training class I'm putting on next month -- but I might pretty them up a bit.
Best to you,
Goober Dave
Pay no attention to the picture of the SPST model in this web page. It's a Thorsen Model #35-405, which is DPDT ON-ON.
http://www.frys.com/product/2874604?site=sr:SEARCH...
Best to you,
Goober Dave
You have a single DPDT toggle switch, wired as described previously, but this time it is attached to the back of the cutout.
You have a bump stop at each end (dowel rod attached to window frame?) that aligns with the toggle switch. When the switch runs into the dowel, it flips, switches polarity and changes direction.
Best to you,
Goober Dave
Best to you,
Goober Dave
I did find this http://www.practicalmachinist.com/vb/general/how-m... which might give a starting point.
Bill
"Why not the best?"
Jimmy Carter
