Need help with Extracting Section from plane Automatically
1.Is there a function in catia macro which can extract a section with jus plane as input. a macro to give a section of any part with plane as input.
2. Once section is extracted; what function can be used to extract the end coordinate points automatically
Barath :)
RE: Need help with Extracting Section from plane Automatically
As far as I know, Sectioning is available in Assembly Workbench and results can be exported as a CATPart (for example) - for this you have to insert the part in a temporary CATProduct. From there you can get points coordinated.
Or you can use create some additional geometrical elements in part (like plane intersecting the part, get intersections, again points a.s.o.).
The idea is that you have first to create some additional geometry to get what you want.
Did you tried something?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
