Need help in Catia Macro
Hi .. I wrote a macro whihc takes the inertia parameter from catia and writes it in excel. I m struck in between; i tried to put a loop; it stops working. can someone help me with debuggin this code
Sub CATMain()
On Error Resume Next
' suppose you have Part document opened in active window
Dim PartDoc As PartDocument
Set PartDoc = CATIA.ActiveDocument
Dim PartRoot As Part
Set PartRoot = PartDoc.Part
' get parameters collection
Dim objPartParams As Parameters
Set objPartParams = PartRoot.Parameters
' find desired "Inertia" object, which name is defined in strInertiaName variable
Dim objSelection As Selection
Set objSelection = PartDoc.Selection
Dim objInertia As Object
Dim strInertiaName As String
strInertiaName = "InertiaVolume.1"
Call objSelection.Search("'Digital Mockup'.Measure.Name='" & strInertiaName & "',all")
If (objSelection.Count = 0) Then
Call MsgBox("No inertia with name " & strInertiaName & " can be found! Exiting...", vbCritical, "Inertia not found")
Exit Sub
ElseIf (objSelection.Count > 1) Then
Call MsgBox("Multiple inertias named " & strInertiaName & " found! Exiting...", vbCritical, "Inertia not found")
Exit Sub
Else
Set objInertia = objSelection.Item(1).Value
End If
' retrieving all parameters related to particular inertia
Dim objInertiaParams As Parameters
Set objInertiaParams = objPartParams.SubList(objInertia, True)
' get parameter called strParamValue (in this case "BBLx")
Dim strParam() As Parameter
Dim objParam() As Parameter
Dim strParamValue() As String
strParam(1) = "Gx"
strParam(2) = "Gy"
strParam(3) = "Gz"
For i = 1 To 3
Set objParam(i) = objInertiaParams.Item(strParam(i))
' get it's value (in a string)
strParamValue(i) = objParam(i).ValueAsString()
Next i
' display value
Call MsgBox("Value of inertia parameter " & strParam(1) & " = " & strParamValue(1))
Call MsgBox("Value of inertia parameter " & strParam(2) & " = " & strParamValue(2))
Call MsgBox("Value of inertia parameter " & strParam(3) & " = " & strParamValue(3))
'Start Excel
Set xlApp = CreateObject("Excel.Application")
'xlApp.Visible = True
'Set xlWB = xlApp.Workbooks.Add ' create a new workbook
' or
Set xlWB = xlApp.Workbooks.Open("D:\Barath\Automation\Trial.xlsx")
'Set xlWB = xlApp.Workbooks.Open("C:\Foldername\Filename.xls")
' open an existing workbook
' example excel operations
With xlWB.Worksheets(1)
For i = 1 To 3
.Cells(i, 1).Value = strParamValue(i)
Next i
xlWB.Save
End With
xlWB.Close False ' close the workbook without saving
xlApp.Quit ' close the Excel application
Set xlWB = Nothing
Set xlApp = Nothing
End Sub
Barath :)
Sub CATMain()
Exit Sub
Exit Sub
Else
End If
strParam(1) = "Gx"
strParam(2) = "Gy"
strParam(3) = "Gz"
For i = 1 To 3
Next i
' display value
'Start Excel
' or
For i = 1 To 3
Next i
xlWB.Save
End With
Set xlWB = Nothing
Set xlApp = Nothing
End Sub
Barath :)
RE: Need help in Catia Macro
First, you should tell us what are you using (vba, CATScript....).
On the other hand you could use SEARCH function in forum see Link or even more here
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
