Using SolidWorks Simulation for Submarine
Hi. I'm trying to run a simulation on a submarine at 1000ft of depth. I set it up using a constant pressure, but I'm having trouble with the 'fixtures'. In reality, nothing will be 'fixed' as it will be completely surrounded by water. I tried using the 'soft springs' option as well as adding anchor points to simulate it being tied down with ropes. I am applying pressure to all of the external surfaces, so I would expect the assembly to stay put, but instead there is a strong resultant force in the y direction, as if there is some other force acting on it. I don't have gravity turned or any other external forces. Has anyone solved a problem like this?
Gabe
Gabe
RE: Using SolidWorks Simulation for Submarine
Cheers
Greg Locock
Cheers
Greg Locock
I haven't the faintest idea. In most mickey mouse programs you either doubleclick on the part in question or right click to bring up a context menu.
Cheers
Greg Locock
Can you split the submarine on any symmetry planes? You can then effectively prevent movement perpendicular to the plane with the added benefit of reducing the run time.
Pete
Thanks for all of the input.
Gabe
thanks again for your responses,
gabe
Cheers
Greg Locock
